weight lifting
if you want to try and lose fat instead of muscle, you need to up your protein intake. its actually recommened that you take in more protein when you are cutting than when you are bulking. i think the calculator on bb.com says 1gram of protein per pound of body weight when bulking and 1.5grams per pound of body weight when cutting.
im about 6'2 and i really started working out back in july 4-5 times a week, and ive stuck with it until now. i've actually lost a lot of fat, but i've bulked up to about 225. everything has increased weight wise, my bench has shot up over 100 pounds what it use to be, squat has doubled, my arms have grown 2 inches. i didn't really watch my diet too bad either, just didn't eat 30 pizzas a day. it seems like i can eat what i want now my metabolism is so fast now. but once you get in the gym and keep the intinsity level high, you'll see fast gains.
well i bought my punch card today and take a tour tuesday. it doesn't look like they have a lot of equipment, but he is suppose to show me how to use every machine, and what muscles they work.
Stretch before, and after your workout for the best effect. It helps the muscles you work to adjust to the added stress. Also, if you REALLY want to lose weight, and are going for the lean and trim look, then you should be running as a 'cool down' after you work out. The more your heart works to supply blood to the muscles being worked, the better.
Also, when you add bulk muscle to your body, you lose a lot of your standard flexibility unless you stretch to accomodate the new muscle.
The best part about working out, is knowing that you're healthy, and it could add years to your life. Not to mention help out against possible health issues later in life, such as heart problems, and lung issues.
I took some personal trainer courses in college, but chose not to stick with it, although I am still very active and go to the gym about twice a week usually. I could technically get certified as a personal trainer, but that's not what I wanted in life.
Soreness of muscles is good, so long as it is NOT in your joint area.
I started early October this year and i weighed 140 at the time then i'd lift with heavy weights, do 7 reps with those till i hit muscle failure, had protein shakes almost everyday, used creatine WHILE workinout man that really put some gains on me in the next couple months, then this month the weight and muscle gains finally started happening alittle over 2 weeks ago, guess my body finally got used to the 2000-3000 calories a day and had to put up with it and the 6 meals a day every 3 hours. now i'm 170 and feel alot better about myself then i did when i was a skinny 140 with no muscle tone.
iceteebone
Banned
iceteebone
Michigan
iceteebone
michigan born
    May 14, 2026
michigan born
    May 14, 2026
