want to build: 8" monster 3" coil.
i dont think the 8' 12 spoke will. mine didnt. had to tap the motor when i built this. i know everyone seen the pic but ill post again lol. and no its not forsale. its a idmax v3 motor. a sundown e8 cone, a tc coil and spider. and a pap cf cap
honestly you wont need a 3 in coil 8. lol. youll hit mechanical limits before thermal.a 2.5 would be the same way, but an overall better setup. just want to do it to do it?
140's at 120hz
//content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif Who needs low end frequencies anyways //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif?
Hunterw, just curious, did you ever measure the t/s parameters of the woofer?
I'm kind of interested to see how that worked out on paper, lol.
i built it just to build it. its never seen power. its a big paper weight lol.
Ohhh lmao, it's working though I'm assuming? Well, in theory? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
You should hook it up to a woofer tester and see what happens //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
8" woofers already have low efficency, using such a hughe coil would hurt..
2.5in coil 50mm tall with a 12mm toplate using spiders DD uses would handle 1k for music.. you just not going to get sick output and useable bandwidth with an 8.. you could build a transmission line for a pair...
yes it works. maybe one day. im sure it plays lower then 65 hz as well:rolleyes:
Is yours a 3" coil? No //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif its a 2.5" coil. Yours is fine, I was talking to the OP. I would actually like to buy yours. PM me if you will sell it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
8" woofers already have low efficency, using such a hughe coil would hurt..2.5in coil 50mm tall with a 12mm toplate using spiders DD uses would handle 1k for music.. you just not going to get sick output and useable bandwidth with an 8.. you could build a transmission line for a pair...
Not true.
PioneerSPL1990
IM FER REAL!
PioneerSPL1990
Canton, New York
ciaonzo
