Voltage Regulation
The only issue is no one with electrical knowledge seems to be chiming in.
asking technical knowledge about circuits that few have experience with is going to be difficult
you're better off asking on a forum specifically relating to your car
Transpo Voltage Regulator is what you need to externally regulate your alternator
Fairly simple to install
Before you go ahead and do that, with your current setup, have you already done the big 3?
Your voltage regulator could be bypassed just by running a secondary power wire to the battery. If you do this, you should also add additional grounds.
Everything you said is completely wrong.
The transpo regulator is not designed to control PCM regulated alternators like his mitsubishi has.
The "voltage regulator" can not be bypassed by simply running an extra power wire.
Just stop.
My truck's stock alternator is PCM controlled. If you disconnect the stock plug from the alternator, it throws a code and eventually will limit my engine rpm to 1500 until it is "fixed"
I ordered a $125 "PCM bypass module" from US alternators. After months of troubleshooting, it still didn't work. I finally just said fuck it and added three alts on a secondary circuit for my sub amps.
Unfortunately for you, adding alternators probably isn't an option. I forget what the Honda guys do to solve their voltage issue, but it might work for your mitsubishi. Hopefully somebody else chimes in with a newer Honda.
09VIC
09VIC
Atlanta
adulbrich
