Voltage Problems, Please Help!!!
  • 5
rlambert02
PHX, AZ
Ok so here's what i already have:
Mechman 220 HO alt
Big 3 wiring
optima yellow top (front)
XSd3100 (rear)
AT OFC 0g throughout
Full copper terminals soldered
Problem: At idle my car sits at 13.8 (dont most cars idle at 14.4?) but when I put my saz-3500 in a week ago it cut out after 3 seconds of play, thought i blew the fuse, then today when i was redoing my build i noticed the fuse was fine so decided to some testing. Hooked up the 3500 again tuned with a dd-1, at it was dropping down to 11.2 at just a little over half volume.
With what I already have shouldn't i be able to hold at least 12v just fine.
Tomorrow im going to do 2 runs of 0g from the front to the rear, but do i go from the front batt to back batt or the alt directly to rear batt.
What should i try to do, get rid of the yellow top and upgrade the front battery? I'm really trying to not add a second rear batt cuz im having a lot issues with rear weight and ride height.
Any help or advice is appreciated. Thanks guys.
Idle seems low at 13.8V. Should be higher than that with that alternator. Go back and triple check all your connections under-hood. Ground, alt, battery, all of them.
And when you had the amp turned up? It was dropping down that low in the front or in the back? And was the car at idle or revved a bit? How long did it take of playing it for it to drop down to 11.2V?
What car is this? That SAZ is a pretty large amp, capable of drawing a good amount of amperage, over 300A. Depending on your car, you may only have 100 or so amps overhead. Your car may require about 50A-ish, and that alt may only produce 150-170A at idle. Do you know what its idle output is?
it dropped to 11.2 after about 10 seconds, if that, and that read at the rear battery at idle, at about 2k rpm i think i was in the 12's. And i Believe idle is 170 amps
How are you grounded from rear to front? Frame or dedicated run?
It's possible there's nothing wrong here, you're just seeing how much that big amp can draw.
Right to the body, i have it grounded on the bolt that holds down the latch for the rear seat, sanded completely down. So the copper ring terminal is sandwiched between the latch and the body. is it better to run the ground from the rear batt to the amp, or my spot to the amp?
So you have front battery to frame, rear battery to frame, and amp to frame? You should atleast go from rear battery to amp. That latch is on the floor? It may not be the best grounding spot.
ok so its better to ground the amp from the battery? and tomorrow ill try to take a picture of what im talking about between the body and latch
A friend of mine surprisingly runs that amp on lower voltage than that no problem. What ohm load are you running that amp at?
EDIT: Does the amp still cut out or are you just trying to keep the voltage from dropping so much?
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
329
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
rlambert02
rlambert02
PHX, AZ
rlambert02
saints747
    May 7, 2024
saints747
    May 7, 2024
