Does speaker wire size really matter?
Not particularly. It's kinda like power wire. You get what you need based on capacity. 14ga should be more than enough for pretty much any set of speakers while 10ga should be more than enough for most sub setups. As for the cca vs ofc debate? Just get whatever is cheaper.
In general...
16 gauge is good for tweeters
14 gauge is a great all round gauge for your's in cabin speakers
12 is nice for subs
8-10 for high power subs
The difference may not be all that noticeable in truth though.
I'm actually running 100 watt 3xl speakers backfed through my stock speaker wiring atm, no plans to change it actually
I run more than that through factory wiring. For the trouble of snaking new wire through the doors there's no difference.
Keep in mind average power over time to midrange and tweets is most likely a tenth of what the amp is rated to make.
I could believe that. The amp im using is rated 300 watts @ 4 and my stock tweeter and 3xl take it without a problem
Callingindogs
Callingindogs
Fort lauderdale, Fl
JoeK
Mike Mccabe
