Voltage problem @ amp
richard cheese
while driving the other day, my 4 channel Phoenix gold amp quit working
I checked the voltage, and while the power wire is connected to the amp, it reads 1.4 volts...the remote wire reads 12v
now when i disconnect the power wire, it reads @ 12V
I thought it was the amp, so i threw in another amp that I have, a US acoustics 4085, and hooked up the power, ground and remote....AND GOT THE SAME THING //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I checked the power wire from the battery, a 4 ga power wire, and it is not compromised in any way. the inline fuse is in good shape too.
I even tested the power wire with it connecected and disconnected to the amp. i tested it at the battery, the fuse, and after the fuse, all under the hood, and I got same results.
I have a 2003 chevy duramax, running a stock deck and a hi to low converter....
does anyone know what the hell is going on?
thanks in advance
What do you mean you got the same results? They all tested good or they all tested bad?
when testing with the power wire in the amp, it reads 1.4 volts, but when the power wire is not in the amp, the voltage goes up to 12. i tested the entire power wire from the battery to the amp, and when plugged and unplugged, i got the same results
And you tried two different amps, and got the same results?
Hmm, that's pretty strange. My first thought would be some kind of short, but I would think that would cause the fuse to blow...idk what to tell you man, I'm stumped, lol.
not much mang....
anyway foolios...I got the problem solved...IT WAS THE FREEKIN INLINE FUSE. it wasnt blown, but something inside wasnt connected
got a new inline fuse and im good to go
thanks everyone for the help...you guys rock! and i mean that:cool:
richard cheese
richard cheese
Bakersfield, Ca
richard cheese
