voltage drops...and protect light
ok will do will i gain more watts in my subs if i upgrade my wiring
You'll be able to sustain a higher voltage. Having a lot of power is great but if you dont have a good ground or thick enough wire to let your equipment discharge properly, then it's like not having power at all.
You will see an improvement. Just dont forget to do the big 3.
ok another question a bit out of the subject but the kit i am buying has a 150 amp fuse for 0 gauge since i am not draining that much power should go buy another fuse thats like 60 or 70 amps?? because this guy at a local car audio shop said i could fry my battery if there a short and becuse the fuse is not low amparage it will mess up my battery and alternator.. is that true?????-
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
480
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
jguti92
jguti92
FLORIDA
terra
SPLBassJunkie
    May 21, 2024
    May 20, 2024
