Volt Meter Questions. URGENT!!
the only other batt u have under the hood would be a good spot since there is nothing else helpin the electrical. read it from the source then i would guess
K!
Would at the amp work too? Like just sticking it in the terminal with the power wire?
Is voltage at the amp and the battery the same or different?
well if you want to meausre drop at the amp connect it at the amp. thats where i would meaure voltage drop to make sure my amps getting enough voltage. yes you can stick the wires in to the +- of the amp
get long pieces of wire from ur batts neg and pos and read the DMM while u have the head decks voltage meter on. then u can compare just a suggestion:)
Will try that, thanks.
They missed you at the car show today. I'm sure you heard about it by now. It sucked that they couldn't demo their cars. It was more for show cars.
MmatsDude
MmatsDude
Los Angeles CA
TurdFergueson2
