Velodyne 6" Sub Pair
  • 4
ciaonzo
TheContinental
11,703
76
WI
6" Velodyne subwoofer pair.
These are gorgeous and versatile. Flat 3 layer woven fiber/foam/woven fiber cone, flat tinsel leads, lots of quiet excursion. 8ohm each. I gave the pair about 300w @ 4ohm and they loved it. Performance is right on par with the Tang Band 6" subs. They have a stiff enough suspension to run free air in your doors as a midbass in a 3way if you choose.
$175 shipped, CONUS.
UPS
cant see photos. what enclosure do these like?
Sorry about that, all my online photos disappeared. I grabbed a photo off the web so you can see what they look like. The pair sounds fantastic in a cubic foot tuned between 30-35Hz.
Can't decide between these and the tang band.... They'd be under the rear seat of a Colorado.
That's a close one, they're both great performers. Cone is stiffer on the Velodynes but the TBs are neo.
The biggest difference between them is the pair of Velodynes will end up being a 4 ohm final load (8 ohm each) and the TBs will be a 2 ohm final load (4 ohm each. Other than that, the *** appeal goes to the Velodynes, not sure if they will be on display in your setup.
Ok so obviously these and the tang bands are 6" woofers so they won't go crazy. But which pair would you say would dig a little deeper? Lol. Would be going underneath the seat of a truck.
104
197
I've been a fan of the JL shallow mounts, and have actually heard a decent box with some Pioneers but the Focal are pretty darn good. The JL TW's...
272
297
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
287
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
