using a capcitor does help..........
..because the lights are dimming?
are you slightly retarded? lol
But the lights don't need the extra current, the amps do therefore if you connect the cap to the lights, they will still dim because the lights draw the same current no matter what , when AMPS draw current the drop varies. Not the same with lights.
WB
Some one knows the importance of CAPS in amplifiers. Although rated in micro farads, They do the same thing 5 FARAD caps do.
WB
NO.
I just told you why the caps inside amps are small compared to audio caps.
Caps inside the amp are using HV so small current needs to pass through them to give the proper total output.
You audio cap is so large because the amp draws a lot of current at LV to convert into HV.
The output signal is floating around 105V at low current. Go and check with a multimeter.
You wanna keep going toe to toe with an EE?
Ron
WB
you're an idiot //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif lol
WB, Claiming to actually HEAR an improvement by installing a cap is 100% psychoacoustics. There is no other explanation for that.
And this, is exactly what cap supporters need to realize and come to terms with. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
WB
????????? WHAT!!
can we all hear it again?
i still don't believe you. you photoshoped those. plus, you didn't take a pic of any of the multiple caps needed to supply power to this system? shame on you
crapacitors //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
must have photoshopped the stretch marks on the the bed sheet too
and the blue paint that came off the crate these were shipped in, which transfered onto the cardboard box as powder and is now on my sheet and clothes //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
wishbone
wishbone
NJ
audioholic
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
