Type R's power
Maybe I have a huge impedance rise with my box. Never measured it.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif wouldn't the wiring create what ohm your running?
How do you measure this stuff and power your using, with a standard multi meter and when system is on/playing?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif wouldn't the wiring create what ohm your running?How do you measure this stuff and power your using, with a standard multi meter and when system is on/playing?
Yes, but that sitting without the subs play. There is an imp. rise due to other factors. I believe it has to do with heat and the box. So more than likely, you'll be running more like 2+ ohms then 1 ohm, even though your subs are wired to 1 ohm.
Box rise= impedence rise due to heat, the voice coil makes the impedence correct. But when it heats up it varies.You have lots to learn, young padawan
now that is something I have never heard before. Learn something new everyday.
I think I'll go with Type R's with my 2k watts @ 1ohm, I'll just leave the gain all the way down and turn down every bit of bass boost from the HU.
Bass boost should never be on //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I set my gains with the sub level all the way up on my HU for the full 2v of signal and just use that for bass control.
KRYPTO
KRYPTO
MN
mr_malina
