Tweeters
Tweeter Box? You mean a crossover? Kind of lost here
This is what I mean I'm trying to add it to my system in my car
Do you own an amplifier? Do you even own a head unit?
Not to come off as rude but you might want to consult with a reputable shop to get you going with this.
I have the whole system Head unit amp and four 12's Just trying to add some treble
You need to find out what ohm load they are showing. So us a DMM and measure the ohm load. Find an amplifier that will accept the ohm load. Example: It measures 4ohm I would look for a 2 channel amplifier and run it in a mono configuration. Left positive right negative on most 2 channel amplifiers.
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
9K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
fjack
CarAudio.com Recruit
fjack
New York
HondaCRV03
Brendon Jenness
    May 8, 2024
    May 8, 2024
