Tweeters
Tweeter Box? You mean a crossover? Kind of lost here
This is what I mean I'm trying to add it to my system in my car
Do you own an amplifier? Do you even own a head unit?
Not to come off as rude but you might want to consult with a reputable shop to get you going with this.
I have the whole system Head unit amp and four 12's Just trying to add some treble
You need to find out what ohm load they are showing. So us a DMM and measure the ohm load. Find an amplifier that will accept the ohm load. Example: It measures 4ohm I would look for a 2 channel amplifier and run it in a mono configuration. Left positive right negative on most 2 channel amplifiers.
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
114
8K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
fjack
fjack
New York
HondaCRV03
    May 8, 2024
DEW123
    May 7, 2024
