tweeters
  • 2
Normally this is a bad idea "to add" tweeters. Sure this will make a lot of noise, but I doubt the music will be anything accurate. The tweeters should be matched with the corresponding woofer. If your current setup is deficient, I recommend a complete component speaker set (the woofer, tweeter, and a crossover that's designed to match them together).
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
9K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
spoolinLLY
spoolinLLY
Chicago
zako
    May 16, 2024
    May 16, 2024
