trying to understand the difference in power (watts) at different loads(ohms) of vari
I recently set my gain on my sub using a multimeter using a formula of sq root of (watts x ohms) to get the voltage
So my speaker is ratted for 2 ohms. It actually measures 2.4 ohms. My amp is rated to put out 500 watts at 2 ohms. But what is it putting out with 2.4 ohms?
I'm wondering if the amp output is a result of a formula related to the load off the speaker and if so how do I calculate the true wattage at 2.4 ohms. Or is it 500 at 2 or close to 2 and 300 at or close to 4 ohms?
I want to get as close to the calculated voltage on the outputs of the amps as I can by adjusting gain.
Am I over analyzing this thing? I think I am simply because I cannot for the life of me find any articles or formulas to solve for what I'm trying to solve.
Nate
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
554
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
Im not a fan of S.Down, and everyone knows why. I wouldnt buy a screw from them. #1. The enclosure is everything when it comes to the performance...
26
Sierra Nate
Reno, NV
Wellyboy
    May 16, 2024
    May 16, 2024
