Trying to slide Excelon into Din Sleeve but won't go?!
  • 4
LankySwag
NJ
God ****, I have everything hooked up and the radio is working great, all I need to do is finish the final touches and it won't slide in. Something is protruding and actually damaging the radio when I try to put it in 2 spots on both sides evenly. can you help? Here are pics
1. Din sleeve
2. Excelon
See the 2 knotches along the top corner? There's two at the same exact spot on the other side, something's up.
Thanks
pull the sleve out ant try it outo f the car. it takes like 2 seconds to pull the sleeve out lol. just bend the tabs up
looks like it might be catching on these?
I had them pushed in but they like curved due to the radio opening so I thought it was them and pulled them out, didn't work .
---------- Post added at 02:38 PM ---------- Previous post was at 02:37 PM ----------
theres something your missing OP just take your time and youll get it in there. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
C'mon pls help, I'm actually damaging the radio
are you puting the radio in the right side up? ive seen this happen before. how far in does it go when your sliding it in before it gets jammed?
All the way in besides like 2 inches hangs out
is this a Volkswagen???? or audi?
also try to bend the tabs with your fingers, the ones that lock and hold the radio. some times they are bent slightly to much from the factory.
but if it is a volskwagon, its the harnedd. you have to really make sure to push the wires below the HU and out of the way because they can be a *****!
take the cage out of the car and see if you can slide the radio in it. then once you can, install..
The din sleeve?
---------- Post added at 02:51 PM ---------- Previous post was at 02:51 PM ----------
95 Ford Escort
said this already, he seems to be ignoring this fact. trying to find a shortcut or magic answer when quite frankly there isn't one because we are on the internet. OP take the **** sleeve out. if it fits no problem, make sure you put the sleeve into the opening the exact same way (you might have it upside down) then make sure its the wires behind the radio not causing the last 2" to fully go in.
Doing it now lol
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
660
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
Im not a fan of S.Down, and everyone knows why. I wouldnt buy a screw from them. #1. The enclosure is everything when it comes to the performance...
26
LankySwag
LankySwag
NJ
DonH
    May 24, 2024
    May 23, 2024
