To Capicitor or Not To Capacitor?
  • 4
If you are asking this because your lights are dimming, then yes a capacitor can help your problem, you will still have some dimming, but not as bad. The downside to this is that you can burn-up your altenator quicker. If you go out and get a bigger altenator then it will fix your problem. My advice would be, get a capacitor, if your altenator goes, then get a bigger one, but it's hard to tell how long it will last. So depending on how bad your problem is, you could probably save the extra money and just get a capacitor and play the wait-n-see game. Later
A capacitor will only benefit you if your charging system is free from problems. If your lights are dimming- a cap is only a band-aid to a larger problem- the car not being able to produce enough current. The system is only as good as its weakest link, replacing the alternator with a higher output model would be the better way to go.
take it easy,
-zane
Ok, well I do not have it all put in yet, so I do not know about the lights and all. I am now thinking of HE2s for subs, guess I will just wait and see what happens. Its a 136amp alternator, is that a big one? I think the next option was like a 160amp.
on a new vehical like that with a good alternator their shouldnt be any pro even more so cuz your not pushing that much power.
later
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
Going all Knu for wiring, lugs, and fuse holders. Been using them for the last serveral vehicles and love their products. Battery terminals...
mrmagoo_83
Registered User
mrmagoo_83
Fort Worth, Tx
Snapnakk
    May 18, 2024
    May 16, 2024
