Tips for setting EQ for metal/Rock
Lots of treble, little midbass, and yes it kinda of does sound like noise in a blender, can barley even listen to it. I'm probably EQing wrong, I thought you where supposed to try to lower than raise the EQ setting, should I be raising the low and the high, and then cutting the mids, not as much as I was before?
Before anything, make sure all your speakers and tweeters are in proper phase, check with a 9 volt battery. If you have an amp, make sure its wired properly, is it bridged?
For treble, tweeter placement makes a big difference along with proper gain adjustments. If its a passive component set then put the tweeter on -3 or -6
Midbass will need proper seals and deadened doors.
The auto EQ can only take you so far, the test depends on a quality install.
Another thing with the auto EQ, put the mic on your headrest and take off the head rest cushion and make sure no noise is happening around it when its calibrating.
Yes, you want to cut rather than increase past 0db on your EQ settings.
Bass and large drums are ~20hz - 2Khz.
Guitar and vocals are generally 1.5Khz on up.
Cymbals, snare and high hat is about 5Khz on up.
Try cutting the 5Khz band a little and leave everything else around 0db. You may need to "add" db on some levels, but try to avoid more than absolutely necessary.
Speaker are all in phase, checked twice.
Four channel amp for the front and rear door speakers. Passive for right now.
Front doors have been sealed and deadened.
I have Hertz ESK165 right now, I might just go get the HSK165XL, If there that much better.
Thanks I have tried messing with those settings, I can get it to be "ok" on some songs, but not how I want it to be.
Speaker are all in phase, checked twice. Four channel amp for the front and rear door speakers. Passive for right now.
http://www.caraudio.com/forums/general-discussion/612530-hertz-esk-165l-5-vs-hsk-165-a.html
According to this thread, it seems like the HSK165XL will be a big step up.
awdtalon21
awdtalon21
United States
awdtalon21
BP1Fanatic
    Jun 2, 2026
BP1Fanatic
    Jun 2, 2026
