You said the DC's were peaking at 37Hz, what did the AQ's peak at? I'm assuming mid 40's, so I could see the DC's hitting the lows better. Probably not as peaky also, so the SQ could be better.So far I like the DC's over the AQ's for sound quality. Much deeper richer lows that are just downright punishing. The box thats in there was 2 yrs. worth of testing with the AQ's so It's not surprising the q's proved louder in the box.
The DC's take more power longer for sure. Biggest draw back is mounting. You can't mount normally so you have to take the box apart if you have any problems.
Link no worky
35w x 15h x 25.5d
Had a blast at the 2nd annual St. Judes Bass Off
Last week 147.6 Meh
This week 148.6 38hz BetterLOL We'll be poppin 50's in no time:viking2:
Big thanks to Peas! You the fawking man
The AQ's were peaking at 40hz when I pulled them. The mounting issues are being addressed as we speak.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifYou said the DC's were peaking at 37Hz, what did the AQ's peak at? I'm assuming mid 40's, so I could see the DC's hitting the lows better. Probably not as peaky also, so the SQ could be better.
Interested to see what kind of numbers you can get out of the DC's. Hope it makes the mounting hassles worth it //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
