system only turns on when headlights are on...WHY?!
bobwire
hopefully this is a newbie question with an easy fix, but i am confused as hell so please help me out!
so i recently bought a used car with an aftermarket sound system already installed in it--aka i didnt install it so i dont know how its currently wired... problem is, it'll only turn on when i turn the headlights on! lights go off--so does the sound system. when the system is on, it's fully functional. but when i switch off the lights, no more music..
i should also add that when i turn the engine off, the lights (and hence the system) turn off, as well as the in-dash clock, AND the thingie on the ceiling that lights up when u open the doors also turns off.
anyone know whats goin on? it just occured to me that it may just be a weak battery (since i just bought the car, and i know the previous owner wasnt driving it much)? this isnt a super big deal, since i can still use the system but its annoying not being able to use it when the engine is not running, and i lose all radio presets, and the clock in the headunit resets everytime as well.
THANKS
sounds like they used the headlight switch as a 12v or the remote turn on lead for the system. check your wiring. use the radio fuse and tap into that for a remote turn on.
Sounds like a safety feature the installer worked in for you. You want to make sure oncoming cars can see you if they can't hear you... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
just checked and neither the amp nor head unit turn on sans headlights. BUT when i DO turn on lights, head unit turns on, but amp does NOT. GAH!!!
ps. which one is the ignition wire there are a bajillion wires chillin under the steering wheel!
bobwire
bobwire
central jersey
XanderMoser
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
