Sunroof rattle/noise issue
dacfan
Hey guys i'm new to the forum and wanted to know if anyone else is having major sunroof rattle? I have a 2001 suburban and the sunroof is flapping so hard it's a big distraction. I'm planning on removing it and was wondering if anyone else has done this and if so what would be the best way to do it?
Yeah it,s already got two layers i'm wanting to remove the glass and track. Was hoping someone had already done this and could give me some pointers. Is sound dampening material flammable?
crap idk that either it would melt fs..
Take it to a body shop if you want to properly seal up your sunroof. I've seen it done and if you don't know what you're doing with fiberglass/bondo/paint it'll look ghetto as hell.
This. Seal it off by removing it/replacing it with a piece of metal. Seen people do this.
Haha I sealed mine with black silicone on the out side, removed my headliner for deadening and in the headliner is a bracket for the track and what not and ended up sealing around it inside as well. Still have yet to put the headliner back in, I believe the only thing holding the window in is the silicone and it’s been fine for the last year. Obviously not usable
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
Example. H.depot or Lowes should have some also? or a hardware store
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
Play the system when your muffler is cold and crawl under there and grab shitt until it quits rattling. That is really the only way to fix the...
10
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
dacfan
dacfan
south carolina
Chrishxc718
    Apr 28, 2024
    Apr 28, 2024
