Twistid
Sorry dude, its just you... the only time you need to use all terminals is when strapping.and jacob please chime in and help use out with this confusion
Thank you, as I stated before you only need to use all of them if you want to, or when strapping.Sorry dude, its just you... the only time you need to use all terminals is when strapping.
I am recommending that because it is what is stated in the manual, I also would not recommend running it at .5ohms either, not that it will not work, rather it is out of the guidlines of the manufacture, and therefore I can't suggest it being a rep of Sundown.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifsorry bizzle manual wins everytime especially when he is trying to run it at 1 ohm and if your right i will admit i was wrong however kamanian who has ran many agrees that he needs to use both..
it should still have warr. then, do you have the origional reciept? if not can you get it from the guy you bought it from? It comes with a 2 year warr. you still have over a year left.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifIt is used. It was originally purchased in april this year.
Your accessibility and willingness to help makes me want to try Sundown next.11.8 with the vehicle off could be a bad battery or a very poor ground - should be over 12.
Also, you can use just one + and just one - on the amp - that is no problem.
If you have the original invoice from the amp it is under warranty and I could look at it if you like.
Glad to hear it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I do my best.Your accessibility and willingness to help makes me want to try Sundown next.
indeed. thats why i ran sundow amps for awhile. (no system at all right now)Your accessibility and willingness to help makes me want to try Sundown next.
The Truth! It's a standard mono-block amp so the speaker terminals are connected internally. There isn't any need to connect them externally and no where in the manual does it say you HAVE to connect all of them. The diagram pictured is showing you an option. You have the option to use one + and - or both.Also, you can use just one + and just one - on the amp - that is no problem.
