Subwoofer LEDs Help
Many general auto parts stores sell very simple control units for lights.
Many come with on/off/bass modes. The "bass" mode either works via built-in mic or vibration depending on the unit.
They usually cost 20$. Just hook it up to power and ground and run the lights through it.
Safe and easy and gives you complete control over your lighting. Hooked this up in a vehicle for interior and exterior strobes and constants.
Alright thanks everyone I tried hooking it up to the subs directly and it worked...I'm keeping it that way until the music module is back in stock, I'll switch to that after.
It is quite likley you are going to burn them out over time, as they are only ment to see around 14volts, and your amp will peak more around 35volts...
If you are going to leave them hooked up that way I'd put a 5w resistor in series with them... If you measure the DCR of the LEDs you should be able to figure out what value to use...
....//content.invisioncic.com/y282845/emoticons/wowflash.gif.89a61f4caede63a11dac36e97d61323e.gif//content.invisioncic.com/y282845/emoticons/coolflash.gif.4f9740e1268764cfe452b9259e375e3b.gif//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif//content.invisioncic.com/y282845/emoticons/wallbash.gif.1310150c49dd52e0fbe1813a0681e5c3.gif
chetomatic
chetomatic
Boston, MA
ahole-ic
vegang
vegang
