Subwoofer LEDs Help
Many general auto parts stores sell very simple control units for lights.
Many come with on/off/bass modes. The "bass" mode either works via built-in mic or vibration depending on the unit.
They usually cost 20$. Just hook it up to power and ground and run the lights through it.
Safe and easy and gives you complete control over your lighting. Hooked this up in a vehicle for interior and exterior strobes and constants.
Alright thanks everyone I tried hooking it up to the subs directly and it worked...I'm keeping it that way until the music module is back in stock, I'll switch to that after.
It is quite likley you are going to burn them out over time, as they are only ment to see around 14volts, and your amp will peak more around 35volts...
If you are going to leave them hooked up that way I'd put a 5w resistor in series with them... If you measure the DCR of the LEDs you should be able to figure out what value to use...
....//content.invisioncic.com/y282845/emoticons/wowflash.gif.89a61f4caede63a11dac36e97d61323e.gif//content.invisioncic.com/y282845/emoticons/coolflash.gif.4f9740e1268764cfe452b9259e375e3b.gif//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif//content.invisioncic.com/y282845/emoticons/wallbash.gif.1310150c49dd52e0fbe1813a0681e5c3.gif
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
224
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
900
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
chetomatic
chetomatic
Boston, MA
ahole-ic
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
