Subwoofer is very quiet
This is how the amplifier and sub are currently set up. The subsonic filter is at 35 hz lpf is at 80 and I have no bass boost. The gain 3/4 full
I am at a loss then.
Turn the Subsonic all the way to the left, turn the LPF all the way up. Does that help?
Do you think if I had the amp wired up and on without a subwoofer connected would that mess it up. I also didn’t disconnect the negative from my battery when I was connecting my amp and I’m starting to think that doing that messed up the amp
I don't know... you said the other amp is quiet too right? That makes me think the head unit may be at fault. I must head off to work now.
There's a setting on that head unit for rear speaker to be set as Full Range or Subwoofer. You may not be wired this way at all, but maybe see if it's set to Full and maybe should be set for sub.
Emanuel Rodriguez
CarAudio.com Recruit
Emanuel Rodriguez
Texas
1aespinoza
