Subwoofer is very quiet
Muffled..... Hmmm. Pull that sub and make sure the positive wire is going from one positive terminal on the speaker to the other positive on the speaker. Make sure the wire from the negative is going from one negative terminal on the speaker to the other negative terminal. These should then be run to the terminal cup... positive to positive, negative to negative... 2ohm. Like the first pic... not the second. The second pic will make the sub quiet. It's free to double check. Also, are you using RCA cables from the head unit to the sub amp?
I already checked the wiring and it’s all good. I am using rca cables straight from the stereo. I also tried the rca cables for my door speakers from my other amp and it was still the same
FIrst aftermarket I installed, I had to enable the sub output in the head unit. I don't remember if it was Pioneer or Kenwood, but it was one of them.
Emanuel Rodriguez
CarAudio.com Recruit
Emanuel Rodriguez
Texas
1aespinoza
