[quote name='Jaguar']
@quackhead I can confirm the subwoofers are connected separately within the enclosure as well as individual left/right terminals from the back of enclosure leading to the amplifier to left and right channels (left/right left/right) in stereo.
That is how the standard 8ohm Kicker Comp 12"s were installed.[/QUOTE]
I was afraid that was the case.
So, if your old subs were in perfect working order, all you needed to do was rewire the old subs in parallel fashion to the Kenwood in bridged mono to take advantage of it's power capabilities.. I posted a copy of the Kenwood owner's manual in a previous post which states plain as day how this is done in the "Connections" section.
I know you are new, but try to follow...the old subs are 8 ohm ea. parallel wiring two 8 ohm subs creates a 4ohm impedance .
Parallel wiring halves the given impedance, Series wiring doubles impedance. Higher impedance load to the amp lowers amp output 99% of the time, a few amps maintain a given power over varying impedances but that Kenwood is not one of them.Ie; lower impedance load allows the amp to produce more power. (For years I avoided DVC subs for the very reason you are having trouble understanding those DVC subs you just bought.) Your amp has a minimum allowable impedance, in stereo and summed mono.
In stereo, as the old subs were wired, you were presenting the amp with an 8 ohm load per channel L/R. The amp does not even give a power rating at that impedance. It does however give a power rating for 4 ohms = 170 watts rms per channel, therefore you can deduct that
at the previous 8 ohm load, it was producing roughly 85 watts per channel rms.
Your amp is rated for 250 watts per channel @ 2ohms. OR 500 watts into one channel summed mono @ 4 ohms.. Your old subs should have been wired to the amp in parallel to the POSITIVE terminal on the LEFT channel and the NEGATIVE terminal on the RIGHT channel, creating a 4ohm load to the amp using both channels combined for an output of 500 watts rms. You should promptly return those new subs and rewire the old ones correctly so you can achieve the same "next level" experience using what you had to begin with.
Save the monthly payments for a future purchase that would not limit you to the ignorance of the sales person who sold you those new subs and told you to only wire one coil per sub, thus in most cases voiding warranty due to burnt coils. And by all means, stay away from whoever wired the old subs to that kenwood.
