subs canceling each other out?
The placement of the subs will affect loading.. but for the subs to actually 'cancel' each other the distance between them would have to approach 1/2 the wavelength of the frequencies being played.. you can do the math if you like, but for subbass frequencies in the trunk of a car, it's a non issue..
So is cone area not important cause i was gonna go with 3 12s but 5 10s has more cone area
12's usually need at least 2 cu ft plus port...10s about 1.5 plus port ...8's about 1 cu ft plus port in general....unless your going sealed cone areas not that important...not as much as speaker quality and proper box design...ive beat many systems in loudness with 4 8's that were running 4 15's...plus mine hit low as well....
Ok thanks guys so 2 12s and i will have a 70 amp fuse i know it depends on alot but could i burp 4000 rms on that fuse or what will i get out of it again i know it depends on alot but assuming my electrical is all sound
512
16
528
brooklynjoy2008
brooklynjoy2008
ohio
Phoenix Risen
