Sub suggestion
I've wondered if they were any good. I may keep an eye out for when they go off preorder.
I'd even go so far as to guess that a pair of Xfl-15 would CRUSH a single 18 on your power. A Tahoe? 48"w x 26+"d?... 19" T?... I think 2 lower powered 15's would be your best bet.
That ride is the meat and potatoes of Bassheads.
I've helped /w/ a few. even a pair ol' tired Sa15 will still impress. Maybe not the "best" or world beating results everyone is after but it WILL utilize your power rather well if done right.
24586
Kinda hard to miss the target when you've got that much space available Imo.
What's your opinion on the Lowballer? I want something that i'm sure no one around me has even heard of. It's 900W RMS.
I like headroom with wattage. I've seen way more underpowered system blow up than overpowered ones.
3000 watt amp? I'd look at 2500-2800 watt subs total
1200 watt amp? I'd look at 1000w subs
10,000 watt amp? I'd look for 8000w subs total
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
479
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
336
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
481
Masted85
CarAudio.com Recruit
Masted85
Alabama
Marve_Lous
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
