Sub Sonic Filter??
Depends on what you play through it.
You should be alright, but be careful if you play material below tuning.
Well I play 100% rap.. So do you think I'll be allright? I was thinking of getting a pair of THESE , worth it?
Right now I have a pair of Audiobahn subs, which I could kinda care less if they blow. But would that be a good investment for when I upgrade my subs, (possibly to Type Rs //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif )
i like my audiocontrol EQX. not only is it an equalizer its a crossover and SSF in one unit!! and the crossover and SSF are not controlled by knobs.. instead, a certain resistor yields a certain frequency crossover point. for instance, i plugged in 100k ohm resistors into my EQX to get a crossover frequency of 72hz. i plugged in 300k ohm resistors to set the SSF at 24 hz (my box is tuned to 32hz).. COOL!!!!!
SSF's are for noobs. Know your subwoofers mechanical/thermal limits, don't over power it, don't be a gain/volume master, and you're fine. I haven't used an SSF in nearly 3 years...
Also, in-car...I wouldn't tune any lower than 28hz...it's useless. A box is SQ-wise good to half an octave below tuning. So, the 28hz box would be good to around 21hz. Not too much music extends to 20hz very often, even rap...it'll be mid 30's on low-notes. peace
NG
NG... are you a gain/volume master? I see your good with your hands... whats the matter?
Good old palmala handerson been keeping you busy? huh biitch? what???
j/j
i don't hate you, i just don't like you
Decipha
www.EFI Dyno Tuning.com
Decipha
New Orleans, LA
Decipha
michigan born
    May 14, 2026
michigan born
    May 14, 2026
