Sub Rca
I only have one sub output from the HU , so going to the amp JL HD 900/5 . Do I run a splitter to the inputs ?
Sent from my SM-N950U using Tapatalk
Yep, the subs don't move at all when both RCA cables are plugged in. I updated the firmware this morning. Unfortunately it didn't fix my issue...
33
6K
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
Having to adjusting the sub input sensitivity depending on the music, would be reason enough for me to go with the RCA cables. It does seem odd...
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
If you have an OEM radio and amp, chances are that one has bass reduction as the volume rises to protect the paper cones from tearing apart. So if...
74
tapcola
tapcola
US
tapcola
    May 20, 2024
    May 20, 2024
