Sub options. What to do with a Kicker 750.1?
darkhunter139
I am going to be getting a Kicker 750.1 amp, I already have one Kicker CVR installed right now and was wondering what kind of subs should I get for my new amp?
Here are my options:
1: Get a good single sub that can handle 600-750 watts for around 300 dollars
2. get two new subs for around 300 dollars
3. Just take the cheap route out and add another 12 inch CVR
Which way do you think I should go here?
single sub
edit: unless you have the space for a large enclosure
Nope just have an Accord so it can not really be that big of an enclosure.
The one I have in there right now is about as big as I can get
So what are some good options for a 12 inch single sub running around 750 watts?
Ok and I have a ported box tuned to 2.25ft^3 at 36 htz that I built for my kickerCVR
Will this be good for the fiq12 or should I build another one?
the volume is good, but the tune is too high
build new and tune lower....between 28 and 33 for the 12" q
you could modify your current box, but I recommend build new
darkhunter139
darkhunter139
PA
darkhunter139
