Sub and Amp help
So i'm looking for some options in regards to a couple subs and a amp for them. These will be going into a 2008 dodge ram quad cab into a box under the rear seat. I'm planning on buying a pre-made box from fox acoustics, the options are either a 2 10" in a vented box, or 2 12" in a sealed box.
Sealed
http://www.foxacoustics.com/ProductDetails.asp?ProductCode=DQC-212-S
Vented
http://www.foxacoustics.com/ProductDetails.asp?ProductCode=DQC-210-V
What i'm looking for in the subs is a nice punchy sound, not the a rumble sound if that makes sense. I listen to metal and also top 40 stuff and almost everything in between. I'm not looking to spend a bunch on the subs don't really want to spend more than $150 per sub(less is better don't need the best subs around just good quality), and around $200 for the amp.
The Subs will be going in at the same time as new front components which are CTX65CS, and a Arc Amp. If this makes any differance in the sub choises.
CTX65CS - Image Dynamics 6.5" Component Speaker System
Amp
FD 2200 - ARC Audio 2 Channel 370 Watt Amplifier
Thanks, i know it's a long post
I would go 12's sealed for what you are looking for. Porting will always give you more output on a certain frequency but will not give you the ability to play all frequencies well. most rock is not 36hz base.
there are quite a few subs that can be had for $150. the magnet diameter could be a concern though. I think the diamond D6's run in .8 sealed but I am not sure if the magnets are more than 6"
I ran into the same thing on our dodge. finding something that had good output, the right airspace requirement, wile having the right magnet diameter. I ended up with kicker subs comp VR's.
for amp I ended up with an MTX 800w d channel. plenty of power and cheap.
RE Audio SE12
2 of these with
Elemental Designs
So i'm looking for some options in regards to a couple subs and a amp for them. These will be going into a 2008 dodge ram quad cab into a box under the rear seat. I'm planning on buying a pre-made box from fox acoustics, the options are either a 2 10" in a vented box, or 2 12" in a sealed box.Sealed
Vented
http://www.edesignaudio.com/product_info.php?t=2&products_id=782
Amp
didnt realize you only have 6 inch width, then these would work beautiful in that sealed box, they are perfect size and meant for small sealed box with the matching ed nine.1
hypnotoad
hypnotoad
Alberta, Canada
mclerico83
