hypnotoad
So i'm looking for some options in regards to a couple subs and a amp for them. These will be going into a 2008 dodge ram quad cab into a box under the rear seat. I'm planning on buying a pre-made box from fox acoustics, the options are either a 2 10" in a vented box, or 2 12" in a sealed box.
Sealed
http://www.foxacoustics.com/ProductDetails.asp?ProductCode=DQC-212-S
Vented
http://www.foxacoustics.com/ProductDetails.asp?ProductCode=DQC-210-V
What i'm looking for in the subs is a nice punchy sound, not the a rumble sound if that makes sense. I listen to metal and also top 40 stuff and almost everything in between. I'm not looking to spend a bunch on the subs don't really want to spend more than $150 per sub(less is better don't need the best subs around just good quality), and around $200 for the amp.
The Subs will be going in at the same time as new front components which are CTX65CS, and a Arc Amp. If this makes any differance in the sub choises.
CTX65CS - Image Dynamics 6.5" Component Speaker System
Amp
FD 2200 - ARC Audio 2 Channel 370 Watt Amplifier
Thanks, i know it's a long post
Sealed
Vented
Amp
