Stock Electrical, Can I go with a large amp at high ohm load?
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Since we are talking about car audio I'm going to retract my statement of saying I'm absolutely right (if I ever said that),but with:
Amp 1000 watts @ 4 ohms = 71 amps
Amp 1000 watts @ 1 ohms = 71 amps
there must be something I am missing because you can't change resistance and keep power the same without supplying a different amount of electrons per second. If you are correct then I'm missing something huge or you're talking about a different part of the system as me because well "that doesn't math" lol.
You're thinking in terms of the output side of the amp. And you'd be correct, the same power at lower impedance would be higher current and lower voltage.
Everyone else is talking about the INPUT side of the amp. From the battery. Voltage is constant, at 14V. So, for 1000 watts and 14V the input current is 71 amps. Regardless of the OUTPUT impedance.
This is where efficiency comes in. You don't get something for nothing - any amp will always draw more power from the battery than it sends to the load. An amp that's 80% efficient supplying 1000 watts will draw 1250 watts from the battery. If the efficiency of the amp is better at higher output impedances, then it'll draw less power (and less current) than with a lower impedance load.
... Phizzikz
Not only that, but what I said earlier about the 4 ohm at a specific wattage pulling less current than .5ohm, nobody has agreed with yet for some reason. Yes, efficiency plays a role but I'm talking about the actual laws of the universe. Even if efficiency was somehow magically the same, the lower resistance at same power would pull more current and push less voltage than the higher resistance. I will demonstrate this clearly:
Wattage = Voltage X Amperage and Resistance = Voltage / Amperage
therefore...
If Wattage remains the same, and Resistance increases, Voltage increases and Amperage decreases
Edit: need to add something...
Likewise... If Wattage remains the same, and Resistance decreases, Voltage decreases and Amperage increases
I agree that even if efficency wasn't the issue, you would pull less current at 4 ohms than .5.
Im just gonna stop posting in this thread hahahha.. I made myself look like an asshat here
Sent from my draconis using Tapatalk
Lol, yes
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
517
744
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
486
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
618
boomzabit
boomzabit
Minnesota
mlstrass
    May 24, 2024
