SSC6 Crossover *Quick Help*
scotsman
I noticed that the woofer in my driver door from this comp set wasn't working. I took off the crossover and found this. Is there anyway to fix this or do I need a new crossover? That wound up coil is hanging loose on 1 side, can I just glue it back together, I'm guessing i need to get it to sit in that little hole where it came out of and make a connection.
Hey man, not sure how to fix that, or if a fix will work, but I do have 1 used SSCS6 crossover that I could sell you if you end up not being able to fix that one.
Just throwing it out there for you, just in case.
Yep. Be careful not to melt the insulation on the wire too much... it's clear, but it's there! soldering iron, i would recommend 25 watt for that. needle tip. Can you not solder from the opposite/far side of the board?
scotsman
scotsman
SugarLand, TX
headless
michigan born
    May 14, 2026
michigan born
    May 14, 2026
