SQ Guys Who Went From Sealed to Ported?
I've got my 15" Avalanche in a low-tuned ported box right now, and the lows are just insane, even though I really need a sturdier box. Mine flexed so bad it is leaking and basically coming apart inside.
I'm dying to try two of these sealed though, and at least doubling the power. I've seen several people say that the Avas are "supposed" to be insane sealed, but there's only one way to find out. They have an Fs of around 16 Hz.
If I had the room for 2 15's ported, I would do that, but that's not gonna happen in the trunk of my civic. I'm betting that with the right amount of power, in the right airspace, 2 sealed will give me at least as much output as the single 15 ported with even better sq. That would be ideal.
I think, from my very limited experience mind you, that for a single-sub setup, especially 12" and smaller, that low-tuned ported is the way to go. But what does going sealed, while doubling the cone area and the power, give you versus that? That's what I'm trying to find out too. I'll know the answer in the next few months. (at least in respect to the specific woofer I'm using)
It should double the output at all frequencies, so it may be louder over all but maybe not as loud at the particular tuned frequency of a ported box (although it is possible depending on the sub and enclosures etc) I'd take 2 over 1 ported anyday for most SQL subs if you have the power and money //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I think it depends alot on the sub being use too cause i have a 12w6v2 tuned @ 31hz in 2.0 cu ported box and it sounds very peaky in the 40hz - 50hz region and the low end (30hz or lower) isnt that great but overall its loud as hell(flex doors and windscreen) with about 600 - 700 watts. I had it in a seal but a plywood box 1.25 cu sounded outstanding and less muddy and boomy and sounded better with more wide range of music but downfall is output.
WhoSayWho?
Preston Caught a Predator
WhoSayWho?
Hempstead State Park
bassaholic
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
