Speaker sensitivity
In all honesty, it's not really something to concern yourself with too much. That spec pretty much goes out the window once you install the speaker, as efficiency is dictated by the installation conditions.
ditto
i am still learning about parameters and numbers and such... but from the limited knowledge i have i know that the efficiency reference means very little when you factor in the install and when you apply more than 1w. you can use it for reference though when comparing two speakers in identical enclosures. the higher efficiency speaker will be louder in a box that is exactly identical... but also remember that power is a big factor too.
Scarenius
Call me Ravo
Scarenius
Michigan
Scarenius
michigan born
    May 14, 2026
michigan born
    May 14, 2026
