Soundqubed build
4bannger
FLA
So It's time to start rebuilding my sub stage and Ive decided to go with some soundqubed subs. I want to go with 15" subs. I'm on a budget I have an ideas I'm pondering on 4 hds315's walled behind my second row in a ported box. Would this be a good set up on a budget?
Vehicle: toyota sequoia
Box location: behind 2nd row , third row removed
Max space: 40"high, 48"deep, 48" wide
Powered by: soundstream ta1.3000d possible getting another down the road
same idea I have lol, but yeah a good budget loud setup just the box is going to cost some cash since its going to be walled
Wat? My wall costed me 280 bux carpted and painted and its made of birch.... not expensive at all.
You have a ton of room for a proper box. I would do the subs in an upside down u shape with the port on the bottom in the center. Do like 15 cubes tuned to 38 with 300 sq. Inches of port area. Should be loud as crap if you properly seal the wall of from the back of the car, which in IMO makes or breaks a wall setup.
Shouldn't cost me anything more than carpet. I get free material from work
Theres 2 BNIB soundstream ta1.3000d's in tha class's....$250ea IJS
I payed $300 for mine shipped to my door. I would rather pay the extra $50 for the piece of mind in knowing I have the original order my name so if I ever do need to use the warranty is much easier. I'm not against buying used by any means but for only $50 less than what I payed for mine is rather spend the little more to know for sure everything goes smoothly
Looking to buy 1 Soundqubed hdc4 15” basket/ frame with gasket.
16
4bannger
4bannger
FLA
mlstrass
