SoundDigital 5k 2ohm
Pyromaniac4food
Cosmetically ugly. marks, scratches, nicks and scuffs. 6/10
Remote wire terminal is stripped. (Was purchased like that with no warning //content.invisioncic.com/y282845/emoticons/wallbash.gif.1310150c49dd52e0fbe1813a0681e5c3.gif )
Missing screws for speaker output.
Works like a champ. I never ran it below 13v
WILL THROW IS COPPER DOUBLE 1/0 INPUTS
600 OBO I need to get this sold.
Accepted trades:
4v+ pre out double din
Subs/amp that I can run on stock electrical. (Downgrading)
Will work with you on shipping
Soundigital amps came to the US well before Taramps, iirc
Correct.
This beast is rated at 12.6v guys plenty of power to go around!
From the site:
• Maximum power (*) = 5KW
• Frequency response = 5Hz to 20kHz
• Input sensitivity = 0.5V to 6V
• High Pass Filter = 5 Hz to 1 kHz
• Low Pass Filter 50Hz to 20KHz =
• Supply Voltage (**) = 12,6V (10V to 16V)
• FA Dumping Factor = 100 @ 1Ω - 200 @ 2Ω
• Total harmonic distortion =
• Consumption at rest = 2.5A
• Maximum consumption (resistive load) = 500A
• Maximum consumption ( music signal) = 400A
• Installation SMD = Yes
• Weight (kg) (***) = 6 kg
• Length = 354mm
• Width = 270 mm
• Height = 73mm
• Versions (****) = 1Ω and 2Ω
• Power to Double impedance specified = 4KW
(*) Power in Watts RMS with stable supply voltage 12,6V.
(**) Voltage 14.4V above should be applied only in competitive character
(***) Weight with packing and rounding freight calculation purposes .
(****) Check the impedance in the pasted identification label on the amplifier.
Pyromaniac4food
Pyromaniac4food
Socal
Pyromaniac4food
