smoking coming from voltage meter? whoa.. helpppp
bran_zimm
huge problem.. hooked up this lil meter i bought from radio shack to tell me the voltage.. like u put the black thing on the ground wire and the red one on the power wire and well... my moms friend showed me how to use it.. hooked it up to the battery when the car was off it showed like 12.3 volts.. well i wanted to see what it was doing while my system played and i did that and smoke started coming out of the gadget but i put the lil metal things on the ground and power terminals on the amp... and now something is going on wiht my system... what the hell happened?
Unless you set the meter range wrong, there's no reason for it to burn out...and there's certainly no reason for anything to go wrong with your system. Take a pic to show how you were measuring the voltage...you should have had the meter in parallel with the circuit, like you described.
i bet as stated up there you had it set for amps...thats about the only way to cook it. if you read the warnings on the unit or in the instructions im about 99.9999999% sure it will tell you the samething..also if there is loose metal inside the unit.
bran_zimm
bran_zimm
ohio
audiolife
michigan born
    May 14, 2026
michigan born
    May 14, 2026
