speaker wiring problem
lpmaster
i ahve a 4 channel amp but with what im using it for, im gna need to put 2 speakers per channel....do i just wire them up to the amp the same way as if they were their alone? onyl they would be like stacked on top of either otehr...?...or whats this about series and parrallel wiring....i dont get this stuff....but i like doing things myself...any help would be appreciated...sorry if this is hard to understan what im asking....
whats the ohm load of the speakers it should be listed on the back
whats the amp stable at?
just to be safe... connect the - of one speaker to the + of the other and use the remaining
wires to connect to the amp, so your using a - from one speaker and a + from the other
with the other two terminals connected together...just to be safe until you find out the
exact ohm loads
The pioneers are 4ohm
The kenwood amp is 2ohm stable stereo
You could just "stack them" like you said, this would be a parrellel connection so each channel would be running at 2ohms.
Just "stack" two speakers per output and you will be fine.
lpmaster
lpmaster
San Diego, CA
stones
BP1Fanatic
BP1Fanatic
