SK-1500.1 jumps into protect at high volume
I love how it took till like the 5th post before someone mentioned voltage. This is not a matter of shoddy equipment, stop trying to kick Skar in the nuts. It is quite obvious the amp isn't seeing proper voltage when the deck volume starts to climb. Check connections, check your battery. Continuing use like this will destroy batteries, amps and potentially alternators.
Voltage was fine, my wiring wasnt the best but Steve said it was due to intermittent shorting due to vibrations inside the amp. It was all internal
First time i have ever personally seen or have had an amp die due to being mounted on the box quite honestly. There are people running chinese amps on boxes that havent died yet
Repairs paid for and SK-1500.1 is being returned to me now! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
SK-1500.1 rturned and installed with velcro to the trunk carpet. Plays just like it did but has yet to jump into protect. Steve must know what he is doing! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
355
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
594
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
970
All you need. I've been running these for years in 3 different vehicles. https://www.amazon.com/dp/B01BL57JO2/?tag=caraudiocom-20
852
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
JoeK
JoeK
Ringtown, PA
cdc351jeferson
audiobaun
    May 19, 2024
    May 19, 2024
