SK-1500.1 jumps into protect at high volume
JoeK
It just started doing this yesterday. When i play music at higher volumes the amp will jump into protect in about 3-4 seconds in doing so. Low volumes work great, its just when i go into high volume. The subwoofer is fine and not blown or damaged.
I contacted Kevin about repairing it out of warranty, but ill weight that against the cost of an AQ2200D used, or maybe even a Crescendo BC2000 new
hey joe, you check all your power and ground connections with a DMM? Go over each onefrom the battery back with a DMM and especially across the fuse holder, you might have a loose connection causing voltage losses.
That's where I would start too!
Connections were tight, and voltage was perfect at the amplifier tested with a DMM. It would go off at my full 14.4V.
I opened the amp before i packed it up to check it visually and i didnt see anything wrong with it at all.
The sub looks fine, the amp looked fine and the electrical looked fine. Even had new batteries... The amplifier is throwing the red light so thats what i have to blame for now. It was only $28 to ship to Amp medics.
discrepencies?
Hmm? It seems odd how it all happened. I put my gains up to clamped 1500watts power, it lasted maybe 2-3 hours of playtime before it kicked off. Once it kicked off, it did it ever since at any high volume regardless of gain setting
JoeK
JoeK
Ringtown, PA
cdc351jeferson
