Simple Question: What screw do I use to mount a subwoofer to the MDF enclosure?
I know it's a simply stupid question but I am not 100% sure the best screw that will hold the best for a 10" sub to a 3/4" MDF enclosure.
Wood Screws?
Drywall Screws?
Something else?
Also how long should they be??? 3/4" length? more? less?
Thanks so much for the info.
I would get some t-nuts and socket head cap screws
T-Nut
Socket Head Cap Screw
For the screws I would use 1" to 1-3/4", whatever is easier/cheaper for you
I usually drill my holes, fill it with some bondo, and put in the screws before it hardens. It creates a perfect seal.
The type of screw I use are 1" security screws.
Depends on sub. Most of the stuff listed above is over kill for what most guys run. I am not saying they are bad bc they are most definitely no. It's like running 2 runs of 0 gauge for a bazooka powered sub. 3/4" or 1" course thread dry wall screws. Be sure to angle the screw slightly away from the sub. Be careful as it's easy to slip and puncture the surround.
I like drywall screws because the neck of the screw is flat and rests flat against the gasket. It's wise to drill a slightly smaller hole where you will put the screw. This helps with screw alignment and prevent wood splitting.
I would run a pair of 15s in an suv.. or run 4) 12s
24
I think it is the input sensetivity. Indicating you can wire direct ftom speakers.
21
I went with those simply because they fit, the cutout is round, and the hole will take a 6.5 coax. Cutting a square hole in a boat for a speaker...
21
5K
I think you're going to find this is true across the board. Technology has come so far at this point that even the absolute rock bottom unit that...
falconman515
Fresno, CA.
Slo_Ride
