Central Region Simple Creations car show Zion, IL
IA,IL,IN,KS,MI,MO,MN,NE,OH,OK,TX,WI
BigJoker
Team D.O.A V.P.
2,126
Chicago,IL
Simple Creations car show will be hosting their annual show on August 8th 2009. at 2500Shiloh Blvd. Zion Il 60099. There will be a sound off also using the Term Pro meter. It will be three classes, Trunk class, Truck/SUV class, and a modified class. 9:00-5:00 tell all your friends come out and bring the Bang!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
so no DOA will be present at Corey's show? yall better be bringing it then for the Oshkosh show, thats all I gotta say.
most likely not. we had plan on going to the sudden impact show before we knew about Corey's. shockwave is suppose to be coming to it. the owner claims he is doing 170's in a vett. but we will go to oshkosh.
Not sure what show I'll be at next as until I get my problem figured out there's not much sense going anywhere...
you better go beaner. i need someone i can pick on.
I went with those simply because they fit, the cutout is round, and the hole will take a 6.5 coax. Cutting a square hole in a boat for a speaker...
21
5K
I think you're going to find this is true across the board. Technology has come so far at this point that even the absolute rock bottom unit that...
I would run a pair of 15s in an suv.. or run 4) 12s
24
No Issues out of my CT Sounds amps..EQ, 6.5s. There is not one company out there that hast ever had a perfect QC run that I can think of.Hard to...
BigJoker
Team D.O.A V.P.
BigJoker
Chicago,IL
GearGuy2001
    Jun 1, 2024
    May 31, 2024
