Silverado craptastic build..
Mostly finished up in the back.
I have a similar truck and when trying to install comps where you did I had a problem with the doors leaking. Do your doors leak directly onto the back of your speakers, and if so how did you solve that?
Butyl rope above the speaker opening on the inside of the door. Built it up a bit, some recommend covering that with deadner but I didn't.
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
644
Very true, however I also am having trouble finding a speaker that would appear to fit the bill, several have tweeters and a woofer, but not a sub...
52
7K
I have a nissan and i put mine on a switch that has my aftermarket reverse lights.worse case scenerio,u can do that.i just have to flip the toggle...
This is not subjective. Matching the resistance of a given speaker to the amplifier in use is part and parcel of the function of the system. If...
18
Iosias
Iosias
United States
Iosias
maylar
    Jun 2, 2024
    Jun 1, 2024
