Should I strap?
  • 4
jt4x4
CarAudio.com Exclusive
299
81
ND
I have two 1500wrms subs, and two ~2950wrms amps. Easy math says one amp is not quite maxing out the subs, but two amps are overpowering the subs. Should I strap the two and keep the gain low, or should I just use one and set the gain with my oscilloscope?
Pros/cons of strapping? Will one way be more efficient than the other?
Thanks for your time.
- Joe
Yeah i should strap? I have one 0g ran from the battery. Will it be enough for two or do i need to run another 0g?
Put as much power to your substage as your exp warrants Imo. /w/ levels set correctly & electrical of course.
Know your equipment/install... don't be THAT guy
The CT's are nice, That Sundown is a a frik'n beast!
580
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
528
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
624
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
935
jt4x4
jt4x4
ND
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
