Should I strap?
jt4x4
CarAudio.com Exclusive
I have two 1500wrms subs, and two ~2950wrms amps. Easy math says one amp is not quite maxing out the subs, but two amps are overpowering the subs. Should I strap the two and keep the gain low, or should I just use one and set the gain with my oscilloscope?
Pros/cons of strapping? Will one way be more efficient than the other?
Thanks for your time.
- Joe
Yeah i should strap? I have one 0g ran from the battery. Will it be enough for two or do i need to run another 0g?
Put as much power to your substage as your exp warrants Imo. /w/ levels set correctly & electrical of course.
Know your equipment/install... don't be THAT guy
jt4x4
jt4x4
ND
