should I start building this?
Death By Bass
WHATS A SUBWOOFER!?!?!?
or not...
EDIT: measurements are in centimeters!!!
it was designed to fit in a vehicle that I no longer have...
I'm also not sure how the woofers will like playing into a throat that only has about 1/3rd their cone area...
rear compression chamber is larger than needed, I will have to displace some volume in that, but that will require experimentation.
I have one sheet of MDF, which will do the top and bottom pieces, so, do I spend the $30 on a second sheet?
The restriction of the throat will only really limit the upper frequency extension right? I think having 1/3 shouldn't really make things terrible.
I say go for it. That's tuned around 35hz or did I read one of the dimensions wrong?
in room, it would only be good for around 45-50Hz extention, in car, it should do down to 35Hz or so.
its meant for the DD9510's I have.
horn length is 237cm (93.3inches) has a throat area of 119cm^2 (18.45inches^) and a mouth area of 1500cm^2 (232.5inches^) (thats PER woofer)
it was designed for SPL, in a station wagon, where the vehicle peaked at about 44Hz.
however, I'm not even sure if the horns would fit in the car, and I dont have access to one anymore anyway :p
alright, I'm not going to bother building this.
does anyone have a vehicle that it would fit in? (measurements are in centimeters) I can give you the proper plans if you're interested in making it yourself.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Death By Bass
Death By Bass
Adelaide, Australia
Death By Bass
